I need help with my wireless network setup...
jared17
Hey everyone, I went out and bought a D-Link DI-624(wireless router), and a D-Link DWL-G520(card), and I can't figure out for the life of me how I'm supposed to get a connection. Basically what I've done thus far is installed the wireless card with all the drivers, and then in the router manual it says im supposed to open up my browser and go to the following site, HTTP://192.168.0.1, but yet I hvae no connection, so I'm not sure how they expect me to go there to setup my connection. I have tried just connecting to my PC directly with my DSL modem and it still doesn't work, so I'm kind of stuck as to how I'm supposed to get this to work. I can still use my old connection to connect using my DSL modem, but when I searched for a wireless network it says there is one called default, but its not encrypted, so I connected and tried to use my old execulink connection that I use with my modem, and it won't connect. Any help as to how the heck I'm supposed to set this friggin thing up would be greatly appreciated.
THanks everyone
Jared
use a rj45 or rj11 or usb cable first to set it all up, make sure everything you type in your router is the same as you type it in your pc card and then use the wireless
