I need help installing sound on my computer
What operating system are you running? If vista or 7 then do this. Go into device manager, right click on the audio device needing a driver and click on properties, click on the details tab, change property box to hardware ID and list what that vendor and device id numbers are. They look like this. I just need the 4 digits after the words VEN and DEV.
XP works the same way too John ;)
One final driver you can try, which I am 99% sure will work this time.
http://support.gateway.com/support/...Audio driver, version 5.12.3506&uid=343370703
Ok,Thanks so much but it turns out my sound works but only through my headphones. It dosen't work without headphones. Is there any way I can fix that?
I've worked with those before, but I can only think the speakers are bad if you're not getting any sound out of them.
BTW John, they look like this:
