Hey guys does anyone know if you can connect Theater Reasearch speakers to my computer. i have an onboard sound card wich i dont think maters because the TR speakers connect by speaker wire, i was wondering if there was a speaker wire to audio ports converter or maybe a do it urself way w/e works
heres the speakers im trying to hook up http://www.trtheaterresearch.com/homespeaker/tr-2810-2811.html
the tall ones
would appreciate it thanks guys
the tall ones
