So, I was doing a new build and everything was great. I added a video card and tested it- great. I added a diamond sound card that was about a year old that I took from a previous build. Set everything up and tested- not working..
The issue looked be the socket on the board due to bent pins
But.... I'm not sure if the sound card cause the whole thing to blow.
But now I have a new board and everything is working great with the video card and all.
Now to the questions....
1. Should I try using the Diamond sound card again? Buy a new one? Not use one at all?
2. I have Logitech 2.1s and they are plugged into the mobo. I test them with a software from the mobo and all speakers are working in the test. But I go to youtube and try to play a vid- no sound at all. Youtube volume up, comp volume up... the default is set to the Logitech 2.1s and it shows that sound is coming from them but still nothing...
I know its long, but I'd appreciate some help. Thanks, all!
