help using wireless connection
mrh12
hello
i have a problem i m trying to connect to a laptop like mine using wireless
network the problem is both laptops can't see each other but at the same time
we both can see the same wirless networks and computers that have a wifi connection
my laptop is toshiba satellite
the other is exact model except its satellte pro
Well if you are both connected to the ame wireless connection.. file sharing is easy.. BUT not entireley safe unless the wireless signal is protected.
To enable file sharing you need to be in the same workgroup(right click my computer, select proprties, make them the same workgroup.)
You will also have to share the folder which has the files you want to share. To do this right click a folder, and select sharing.
Make sure the wireless connection your are connecting to has a password, so other people can not access your shared folder, and just upload files...
Have fun!
