Help Please - no sound
Richardh
Hi,
My sound was working perfectly two days ago and now there is no sound:-
Keeps saying " nosupported audio device available" and
the volume control does not work - " no active mixer devices available" and
when launching itunes " itunes has detected a problem with your audio configuration. Audio/video playback may not operate correctly" and
in the control panel (sounds and audio devices) the areas do not allow me to make volume adjustments...they are greyed out:-
can you please help.
Dimension 5150:-
DVD/CD-ROM Drives HL-DT-ST CD-ROM GCR-8485B
HL-DT-ST DVD+-RW GWA4164B
Disk Drives ST3160023AS 149.0Gb
TEAC USB HS-CF Card USB Device
TEAC USB HS-MS Card USB Device
TEAC USB HS-SD Card USB Device
TEAC USB HS-xD/SM USB Device
Display Adapters RADEON X300 SE 128MB HyperMemory 128Mb
RADEON X300 SE 128MB HyperMemory Secondary 128Mb
IDE ATA/ATAPI Controllers Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Primary IDE Channel
Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Primary IDE Channel
Secondary IDE Channel
Keyboards Logitech HID-Compliant Keyboard
Mice and Other Pointing Devices Logitech HID-compliant Cordless Mouse
Monitors Plug and Play Monitor - (Standard monitor types)
Sound Devices Unimodem Half-Duplex Audio Device
USB Controllers Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
You'll probably want to re-install the drivers that came with the machine. You should have them on the resource CD.
Hi, Tried that still not working..........Still no luck..... when I try to download the aduio driver an error message appears saying:- "setup is unable to detect a supported product on your system. Please ensure that your product is properly installed before running this set up program." Also when I try to launch the console launcher (creative volume control) it says:- "There is no supported audio device available" A similar message appears when i click the audio console in Control Panel. I have re-installed creative / sound blaster X-Fi.
Computer model:- Dell DM051 ( on the font of my CPU is says Dimension 5150 ). Current configuration says:- Unimodem Half-Duplex Audio Device. Original says:- SOUND CARD SOUND BLASTER X-FI XTREME MUS. I have re-installed X-Fi extreme but does not seem to be showing.
Help please
call customer support sounds like a faulty product u can send it back for a replacement if its coverd under warrenty
