Skip the first paragraph below unless you want to know the reason I'm asking this question.
My Macbook hard drive has failed. When I try starting it up, it doesn't go past a white screen with a "no trespassing" symbol on it. I have tried using the reinstall disks but nothing happens and the disks just get stuck. The data may or may not be recoverable. The Genius Bar could not handle my case, so they recommended me to Tekserve. I went to Tekserve and they told me they would try to get the desired data off and place it onto an external hard drive. However, they said that if they got everything off that I wanted, then the charge would be something over $800. I have done some research and discovered that the price is most likely around the same (and can be more) wherever you go.
Before I shell out this amount of cash, does anyone know how data recovery works exactly?
To narrow this question down, I'm wondering specifically about two things:
(1) Why can't they just automatically get all of my data off, instead of asking me what specific data I want off?
(2) How secure is my data (can I trust that they won't be opening files, or even looking at file names that may suggest important private information?)?
Thanks for the help.
P.S. I posted this here because I couldn't find a forum dedicated to hard drives or data recovery. If this isn't in the right forum, feel free to move it.
