Help choosing a sound card
Breadman177
The only reason i wanted a sound card was to free up some system resources. I know it doesn't make a huge difference but when your system is close to max and don't have alot of money I figure it would help some. Any suggestions on a cheap sound card?
Sound card can't really free up resource. And cheap sound card is rubbish. How much have you got? I recommend you upgrade CPU/ RAM instead
Well hardware D3D acceleration does not work in Vista/7, so getting a sound card isn't exactly going to help you there. Maybe you should consider upgrading your computer instead.
It really doesn't? I've always heard since I first started building computers that it did...hmmm Oooo I'm gonna disable the audio in game tonight and see if I notice any difference, if I do notice a difference wouldn't it be the same difference as having a sound card powering the sound?
I don't have the money right now but if I did get some money it probably wouldn't be more than $30, which is about what I bought my stick of ram for but now the price has doubled. Oh and every price quote I say is really doubled as i will have to buy my wife one also so I'm not running the game better than her and having to listen to those comments daily..lol
I would see you boosting performance by upgrading CPU. Probably Athlon II x3 435 OEM @ $64??
At the moment, have you try overclocking your CPU?
Yeah but I don't have an aftermarket CPU cooler so I can only go an axtra 100 without getting too hot for my liking. I have found one for about $30 that I've thought about getting but haven't actually had the extra money yet. Would my processor overclock to 3 if i can keep the temp down?
The problem I face is Vanguard only supports 2 cores right now, and not very effectively i might add. The first core runs about 85-100% while playing and the 2nd core about 20-35%. So I would really need to get...not sure the model number but the dual core 3.2g one but then thats not future proof cause I bet the next game I play will support more cores then I'll have to upgrade again..lol
i recommend a audigy 2 sound card you can get them on ebay for under $15.00.
a big improvement in sound quality compared to your built-in sound on your motherboard.
Why the heck has the post gone from a question to buying a sound card to a recommendation of a cpu/mobo upgrade? :D
Anyhow,Id recommend getting a Asus xonar....You will definatly tell the difrence in sound quality from that over an on-board chipset.
$39.99 after mail in rebate,i know you said $30 but i wouldnt recommend getting any other sound cards from anyone other than Asus or Creative on that budget.
http://www.newegg.com/Product/Produ...32013&cm_re=asus_xonar-_-29-132-013-_-Product
But it wont realy free up system resources if thats what your wanting more than anything.
