I have problem with sound card.i installed realtek soundman drivers for AC 97 but it asks me to install Multimedia Audio Controller device but i dont have disk is there any other solution for this without disk?here is dxdiag records.
System Information
Time of this report: 11/22/2009, 04:24:46
Machine name: ANONYMOUS
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.090804-1456)
Language: English (Regional Setting: Luxembourgish)
System Manufacturer: FUJITSU SIEMENS
System Model: SCENIC E
BIOS: Version 5.00 R2.14.1534.01
Processor: Intel(R) Celeron(R) CPU 2.66GHz
Memory: 502MB RAM
Page File: 196MB used, 1033MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file ialmrnt5.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) 82865G Graphics Controller (Microsoft Corporation - XDDM)
Manufacturer: Intel Corporation
Chip type: Intel(R) 82865G Graphics Controller
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_101B1734&REV_02
Display Memory: 96.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ialmrnt5.dll
Driver Version: 6.14.0010.4656 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/2/2006 15:09:29, 36990 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: ialmnt5.sys
Mini VDD Date: 11/2/2006 13:06:45, 1302492 bytes
Device Identifier: {D7B78E66-6632-11CF-B466-1130A3C2CB35}
Vendor ID: 0x8086
Device ID: 0x2572
SubSys ID: 0x101B1734
Revision ID: 0x0002
Revision ID: 0x0002
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 22:15:38, 59520 bytes
| Driver: usbd.sys, 4/14/2008 06:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 06:00:00, 52480 bytes
| Driver: kbdclass.sys, 4/14/2008 06:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 03:43:22, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 10/19/2009 02:40:19, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 33.6 GB
Total Space: 38.2 GB
File System: NTFS
Model: ST340014A
Drive: D:
Model: HL-DT-ST RW/DVD GCC-4481B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5593 (Luxembourgish), 10/19/2009 02:25:34, 62976 bytes
System Devices
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to PCI to CSA bridge - 2573
Device ID: PCI\VEN_8086&DEV_2573&SUBSYS_00000000&REV_02\3&61AAA01&0&18
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 22:06:46, 68224 bytes
Name: Intel(R) 82865G Graphics Controller (Microsoft Corporation - XDDM)
Device ID: PCI\VEN_8086&DEV_2572&SUBSYS_101B1734&REV_02\3&61AAA01&0&10
Driver: C:\WINDOWS\system32\DRIVERS\ialmnt5.sys, 6.14.0010.4656 (English), 11/2/2006 13:06:45, 1302492 bytes
Driver: C:\WINDOWS\system32\ialmrnt5.dll, 6.14.0010.4656 (English), 11/2/2006 15:09:29, 36990 bytes
Driver: C:\WINDOWS\system32\ialmdnt5.dll, 6.14.0010.4656 (English), 11/2/2006 15:09:29, 118395 bytes
Driver: C:\WINDOWS\system32\ialmdev5.dll, 6.14.0010.4656 (English), 11/2/2006 15:09:29, 213274 bytes
Driver: C:\WINDOWS\system32\ialmdd5.dll, 6.14.0010.4656 (English), 11/2/2006 15:09:29, 902266 bytes
Driver: C:\WINDOWS\system32\igxpxa32.cpa, 9/19/2006 02:59:22, 524850 bytes
Driver: C:\WINDOWS\system32\igxpxa32.vp, 9/19/2006 02:59:22, 929 bytes
Driver: C:\WINDOWS\system32\igxpxk32.vp, 9/19/2006 02:59:22, 58704 bytes
Driver: C:\WINDOWS\system32\igxpxs32.vp, 9/19/2006 02:59:22, 24704 bytes
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&61AAA01&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_101C1734&REV_02\3&61AAA01&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 22:15:36, 20608 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5778 (English), 3/18/2009 11:02:24, 144000 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 03:42:10, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 22:15:38, 59520 bytes
Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_101C1734&REV_02\3&61AAA01&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5825 (English), 6/8/2009 14:56:20, 30464 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 06:00:00, 7168 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_101C1734&REV_02\3&61AAA01&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 05:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (Luxembourgish), 4/13/2008 16:10:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 16:10:32, 96512 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_101C1734&REV_02\3&61AAA01&0&EA
Name: Multimedia Audio Controller
Device ID: PCI\VEN_8086&DEV_24D5&SUBSYS_10201734&REV_02\3&61AAA01&0&FD
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_101C1734&REV_02\3&61AAA01&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_101C1734&REV_02\3&61AAA01&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_101C1734&REV_02\3&61AAA01&0&E8
Device ID: PCI\VEN_8086&DEV_24D1&SUBSYS_101C1734&REV_02\3&61AAA01&0&FA
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&61AAA01&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 22:06:42, 37248 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&61AAA01&0&F0
Name: Intel(R) PRO/1000 CT Network Connection
Device ID: PCI\VEN_8086&DEV_1019&SUBSYS_101E1734&REV_00\4&295E04A7&0&0818
Driver: C:\WINDOWS\system32\DRIVERS\e1000325.sys, 8.10.0003.0000 (Luxembourgish), 8/20/2008 13:18:42, 171152 bytes
Driver: C:\WINDOWS\system32\e1000325.din, 10/30/2007 12:35:22, 2878 bytes
Driver: C:\WINDOWS\system32\NicCo2.dll, 1.02.0000.0000 (English), 8/6/2007 23:28:34, 28272 bytes
Driver: C:\WINDOWS\system32\NicInstG.dll, 9.10.0005.0000 (English), 8/28/2008 16:37:54, 41080 bytes
Driver: C:\WINDOWS\system32\e1000msg.dll, 9.08.0000.0000 (English), 12/14/2007 11:06:06, 121440 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 8192 bytes
d3d9.dll: 5.03.2600.5601 English Final Retail 10/19/2009 02:25:37 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 4/14/2008 06:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 4/14/2008 06:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 4/14/2008 06:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 4/14/2008 06:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 10/19/2009 02:40:19 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 82432 bytes
system.dll: 1.01.4322.2443 English Final Retail 11/22/2009 03:03:19 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 11/22/2009 03:04:57 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 11/22/2009 03:04:55 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 11/22/2009 03:04:55 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 11/22/2009 03:04:56 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 11/22/2009 03:04:56 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 11/22/2009 03:04:56 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 11/22/2009 03:04:56 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 11/22/2009 03:04:56 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 11/22/2009 03:04:57 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 11/22/2009 03:04:57 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 11/22/2009 03:04:58 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 11/22/2009 03:04:58 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 11/22/2009 03:04:58 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 11/22/2009 03:04:58 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 11/22/2009 03:04:58 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 11/22/2009 03:04:57 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 11/22/2009 03:04:57 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 11/22/2009 03:04:58 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 4/14/2008 06:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 06:00:00 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 06:00:00 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 06:00:00 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 20480 bytes
qasf.dll: 11.00.5721.5233 English Final Retail 10/19/2009 02:26:51 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 386048 bytes
qedit.dll: 6.05.2600.5783 English Final Retail 10/19/2009 02:26:52 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 733696 bytes
quartz.dll: 6.05.2600.5822 English Final Retail 10/19/2009 02:26:53 1291264 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 10/19/2009 02:27:12 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 06:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 06:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 06:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 06:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 06:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 06:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 06:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 06:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 10/19/2009 02:26:35 204800 bytes
ks.sys: 5.03.2600.5512 Luxembourgish Final Retail 4/13/2008 22:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 Luxembourgish Final Retail 4/14/2008 03:42:44 129536 bytes
ksuser.dll: 5.03.2600.5512 Luxembourgish Final Retail 4/14/2008 03:41:58 4096 bytes
stream.sys: 5.03.2600.5512 Luxembourgish Final Retail 4/13/2008 22:15:16 49408 bytes
swenum.sys: 5.03.2600.5512 Luxembourgish Final Retail 10/19/2009 02:40:19 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:00:00 1428992 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 10/19/2009 02:40:19 16896 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:00:00 50688 bytes
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5822
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5822
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5822
System Information
Memory: 502MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
DAC type: Internal
WHQL Logo'd: No
VDD: n/a
Vendor ID: 0x8086
Device ID: 0x2572
Revision ID: 0x0002
Revision ID: 0x0002
Video Accel:
Registry: OK
D3D Status: Enabled
Sound Devices
Description:
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
HW Memory: 0
Registry: OK
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 33.6 GB
File System: NTFS
Model: ST340014A
Drive: D:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
