Front Panel Audio not working :(
You have the same mobo as I do :)
Anyway's heres a translation, sort of where to put the pins.
Aud_Mic=Mic in
Aud_GND=Gnd
Aud_Mic_Bias=Mic Bias
Aud_VCC=Nothing.
Aud_F_R=R Out
Aud_Ret_R=R In
Nothing
Nothing
Aud_F_L=L Out
Aud_Ret_L=L In
Also Make sure your raeading the pin's right. Ijn the manual it ussaly says what pins 1 2 9 and 10 are, and you aer able to fiure out the rest.
No problem, took me a while to figure out exactly what they all did too.
The VCC one im prety sure its actully make for something to plug into it, but my case and sounds like your case didn;t come with a pin for it.
The VCC makes it sound like some extra power or something? but i know it works fine without it.
