Creative Sound Blaster X-Fi Xtreme Audio 7.1
Shane
Super Moderator
Hi all,
at the moment im using Realtec High definiton Audio for my sound (mobo one)
Even though it does sound quite good for intergrated do you think this will be better?
http://www.overclockers.co.uk/showproduct.php?prodid=SC-049-CL
if for some reason the link doesnt work thats a Creative Sound Blaster X-Fi Xtreme Audio 7.1 Sound Card - OEM (PCI) im looking at.
the speakers im using atm are LOGITECH X-140 2.0 which are also great speakers but i l probably be planning to upgrade them with 7.1s at a later date anyway.
also does that card do all the audio processing or would the cpu still do some? does it have x ram or is that only the Fatility?
Thanks in advance for replies ;)
Shane
That card is basically a dressed up Audigy SE. It uses softwares to emulate the X-fi effects and such. It does not have X-ram and is not a real x-fi.
For card under £30, you probably don't get X-ram...
ebuyer is cheaper, by the way...
Hmm okay,btw yeah ebuyer are cheaper for the card but theyre a rippoff on delivery.
£7 delivery + the price of the card so your looking at at least £42
that card you posted mate is PCI-Express,i need PCI :)
Being honest, What does the onboard sound not do, that you want it to? I really don't think you'd see a difference, maybe if you were recording, but not gaming and general music. I think you could save yourself some money.
Just my opinion :)
well mate,il be honest now i had intergrated audio on my last rig,then i got a cheap sound card from a mate and the sound change was amazing.
you could hear alot more things,the sound quality overall was alot better.
I usually choose 5 days supersaver delivery... £28.39 in total
