Cooling System Help
SONY generally has their own proprietary measurements depending on model.
Liquid cooling not only takes up more space it is also a tedious effort to get in
properly. You can also go with an effective cooler if not the same for far less
from an online vendor if you have a familiy member that can order for you. A
look at: http://www.coolerguys.com/alllicoit.html will give you an idea of the
variety of liquid cooling available. Some non liquid coolers can also perform as
well without worry of some reports of leaks. Several can be seen at: http://www.coolerguys.com/so42pe4.html
