changing 9800GT fan speed?
Motorcharge
Well-Known Member
Ok so for whatever reason my 9800 is overheating with CoD4 (oddly enough I can run about anything else with full graphics without any problems) and it seems to be a common problem with this card for cod4.
It was suggested I increase the fan speed on the card with Rivatuner since the cards aren't shipped with the fans operating at full speed and that it should make a noticeable difference.
I've downloaded Rivatuner but I'm not quite sure how to increase the fan speed on the card.
Current Idle Temp: 60*
Nevermind, I figured it out.
GPU idles at 48* now :good:
edit: it's only idling at 45* now
Well this is stupid, it's still overheating with cod4, although it took a lot longer to happen this time.
I'm not even playing at full resolution or graphics yet I can run Crysis on full both without any issues. :confused:
Omg, how can you idle with that high temps? that's like 15c MORE than my GTX 480's idle.. Your previous idle was almost as high as the max temp i saw in gaming with 480.. I think there might be something wrong with the cooling of your card. Maybe you should consider a cheap aftermarket cooler?
Honestly, I dunno. This comp has always run hot, even with the parts I had before it did but I'd never had any issues til now. Even my old 8600 ran around these same temps and I NEVER had any issues with that card. The case is clean, very light dust and I clean it out periodically and its on a desk and we don't have carpet. It gets good airflow, ect.
Can't, I'm broke or I would. Not going to buy one when the issue I have is only for 1 game either.
