Timmie
First of all, I do not have a sound card, I'm using the onboard, I just figured this'd be a better place to put this rather then in the 'motherboard' section, if you feel its needed, a Mod can move this.
Alright, I've just recently been faced with this problem, and I can't manage to fix it on myown. So here's as best I can explain. I have no sound, when I got into device manager, when I look at my sound controller, it says the drivers need re-installed, so I click that, then it starts and gets to copying files and stops and says 'Cannot install this hardware. There was a problem installing this hardware. An error occured during the installation of this device. A device attached to the system is not functioning.'
I'm not quite sure where to go from there. I appreciate any help Thanks!
