3 hours to upgrade Windows 10
Stattovic
When I arrived at work, I turned on my laptop as I had some urgent files to create.
The Lenovo laptop started to upgrade my Windows 10, Installing, configurating, rebooting etc.
I had no idea this was going to take 3 hours, which meant a wasted morning trying to find other things to do.
Is there a way I could perhaps set it to do this overnight for example. I will have to work late this evening to finish what I needed to do.
Any advise would be appreciated.
Many thanks
A Windows 10 upgrade will take a while. Once you're on Windows 10 it won't "upgrade" again until a new major version is released.
It will now just download Win10 updates and apply them when you'll turn off or restart your computer.
A normal upgrade time from a previous version of windows is usually anywhere from an hour to an hour and a half depending on system specs.
If you're upgrading and keeping programs and files it also depends how many of those you have too because they surely have to be migrated?
I think that it will update almost as fast as your connection will download it.
No, thats not true. If you have a previous OS installed and upgrading then most likely the update files have already been downloaded to your system so its just a matter of starting the upgrade. And how long it takes to install is dependent on your system specs and how fast your HDD /SDD is.
Well, I don't "think", I know.
NO, you don't know. You seriously have no clue.
Thanks for these comments guys, the problem with Windows updating was that I needed to do some urgent work, and it held me up.
It says do not turn off your computer. I would rather it did it overnight is there a way in settings to alow updates to be installed.
if you are on windows 10 then the system doesn't update until you go to shut it down and then reboot. Same thing with Windows 7 or 8. It shouldn't start installing updates while you are using the pc.
And if you have Windows 10 Pro you can defer upgrades (note: not updates, upgrades - new builds of the OS) so you can install them at a time that suits you.
Many thanks
I started a Windows 10 Upgrade from Windows 7 Starter at 5pm yesterday. It finished at 1am this morning ;)
LMAO...
Those specs are just as bad as having a 75mhz cpu, 8mb ram and a 500mb hard drive running windows 95. Total cost was $1800
