MineCraft
alright im confused i started a new world or whatever do i just roam and break stuff to unlock things or what
Alpha or Classic version?
Alpha - Set up a shelter, try to survive the onslaughts of monsters from the dark while trying to find dungeons and rare ores to make newer items out of.
Classic - make whatever structure or monument you wish, just for fun.
its alpha i just joined in a new world setting at peaceful was roaming, im not sure how its addicting i was bored after 15 minutes
Found my first dungeon today, had a pig spawner? Wish I could pick it up, it would make good use for Pork :(
What are you guys defining as a dungeon? Cause everything I'm building is underground. Gonna make a video tour soon.
Also, what the heck are those burning cages?? I stare at them for a while, then break them open...and nothing.
Are you playing on peaceful? Sometimes pig spawners pop up on peaceful, but almost never during easy /shrug
haha i havnt play the game in like 3 days cuz my world sucks i can hardly find any diamonds
The easiest way to find diamond is to find a dungeon... finding those can be really easy or very hard depending on your luck, but sometimes you can find a whole mess of dungeons just by doing what you'd do normally... they just happen like that.
Burning cage = Monster spawner in >Peaceful modes ... dungeons are areas that are already carved out underground that make finding rare ores easy. You'll be able to tell if you see the trademark water falls and lava streams down there.
Finding diamond is actually fairly easy. Just dig to the bottom of the map until you get to the bedrock (unbreakable stone). From there start digging around that area and eventually you'll find diamond. I think you need an iron pickaxe to mine it tho.
scott ill make a video of how stinking big my mine is and then ill probly start a new world lol
Well dang I found a lot of dungeons. I found obsidian but apparently I can't get it without diamond
Yeah you can't mine obsidian without a Diamond mining pick. Obsidian is useless at the moment anyways, it takes ages to mine and you can't make anythign with it. Unless you are planning on using it for a building or something.
