lucasbytegenius
Well-Known Member
Thought I'd make a thread where you can show off that brilliant tip that's too small to make a thread about. We all get these sometimes
Mine is the sfc /scannow command. Type it into the Start Menu and press enter. It will scan your Windows installation for missing or corrupted system files and replace them, saving you a reinstall and fixing issues after a bad virus. In WinXP, insert a WinXP CD with the same version of your installation and open Run and type the command.
-The Lucas
-The Lucas
