In desperate need of help
tsaw7
I have bad virus. I am trying to run my anti virus, and it keeps getting blocked. I can't get rid of this thing.
o right ive never had 7, but im guessin its just a fancy vista. Do you got the original disk, to do a repair with?
I just installed the Microsoft anti virus, it said "send file.... to windows defender?" I said yes, and now all the pop ups I was getting are gone. About every 20 seconds I would get a pop up that said so and so file is corrupt. I do not get that message. I am assuming I fixed it.
Please follow this procedure and post both logs.
Please download Malwarebytes' Anti-Malware from here, here, here or here and save it to your desktop.
  • then click Finish.
  • If an update is found, it will download and install the latest version.
If you continue to experience problems after doing this, please post a HijackThis log by doing the following:
Malwarebytes' Anti-Malware 1.44
Database version: 3621
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
1/23/2010 6:44:25 PM
mbam-log-2010-01-23 (18-44-25).txt
Scan type: Quick Scan
Objects scanned: 53650
Time elapsed: 12 minute(s), 13 second(s)
Memory Processes Infected: 2
Memory Modules Infected: 8
Registry Keys Infected: 141
Registry Values Infected: 3
Registry Data Items Infected: 0
Folders Infected: 21
Files Infected: 81
C:\Program Files\OpinionSquare\opnsqr.exe (Spyware.MarketScore) -> Unloaded process successfully.
C:\Program Files\OpinionSquare\opservice.exe (Spyware.MarketScore) -> Unloaded process successfully.
C:\Program Files\MyWebSearch\bar\firefox\NPMYWEBS.DLL (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\1.bin\M3PLUGIN.DLL (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\1.bin\F3HTMLMU.DLL (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\OpinionSquare\msvcp71.dll (Spyware.MarketScore) -> Delete on reboot.
C:\Program Files\OpinionSquare\msvcr71.DLL (Spyware.MarketScore) -> Delete on reboot.
C:\Program Files\OpinionSquare\opls.dll (Spyware.MarketScore) -> Delete on reboot.
C:\Program Files\OpinionSquare\components\opxg.dll (Spyware.MarketScore) -> Delete on reboot.
HKEY_CLASSES_ROOT\TypeLib\{07b18ea0-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eaa-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eac-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f87d7fb5-9dc5-4c8c-b998-d8dfe02e2978} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{53ced2d0-5e9a-4761-9005-648404e6f7e5} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{c8cecde3-1ae1-4c4a-ad82-6d5b00212144} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{17de5e5e-bfe3-4e83-8e1f-8755795359ec} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1f52a5fa-a705-4415-b975-88503b291728} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{a626cdbd-3d13-4f78-b819-440a28d7e8fc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8ca01f0e-987c-49c3-b852-2f1ac4a7094c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1093995a-ba37-41d2-836e-091067c4ad17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{120927bf-1700-43bc-810f-fab92549b390} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{247a115f-06c2-4fb3-967d-2d62d3cf4f0a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e53e2cb-86db-4a4a-8bd9-ffeb7a64df82} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{90449521-d834-4703-bb4e-d3aa44042ff8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{991aac62-b100-47ce-8b75-253965244f69} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{bbabdc90-f3d5-4801-863a-ee6ae529862d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{d6ff3684-ad3b-48eb-bbb4-b9e6c5a355c1} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{eb9e5c1c-b1f9-4c2b-be8a-27d6446fdaf8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0f8ecf4f-3646-4c3a-8881-8e138ffcaf70} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{b813095c-81c0-4e40-aa14-67520372b987} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c9d7be3e-141a-4c85-8cd6-32461f3df2c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{cff4ce82-3aa2-451f-9b77-7165605fb835} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e47caee0-deea-464a-9326-3f2801535a4d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e1656ed-f60e-4597-b6aa-b6a58e171495} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{741de825-a6f0-4497-9aa6-8023cf9b0fff} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8e6f1830-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2b-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2d-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{8e6f1832-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a9571378-68a1-443d-b082-284f960c6d17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e79dfbc0-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{72ee7f04-15bd-4845-a005-d6711144d86a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbc9-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbcb-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{3e720450-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720451-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720453-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{adb01e81-3c79-4272-a0f1-7b2be7a782dc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{7473d290-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d291-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d293-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d295-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d297-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d292-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d296-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{29d67d3c-509a-4544-903f-c8c1b8236554} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e3537fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e9937fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{938aa51a-996c-4884-98ce-80dd16a5c9da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{6e74766c-4d93-4cc0-96d1-47b8e07ff9ca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{cf54be1c-9359-4395-8533-1657cf209cfe} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{de38c398-b328-4f4c-a3ad-1b5e4ed93477} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25f} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{147a976f-eee1-4377-8ea7-4716e4cdd239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{1e0de227-5ce4-4ea3-ab0c-8b03e1aa76bc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{84da4fdf-a1cf-4195-8688-3e961f505983} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a4730ebe-43a6-443e-9776-36915d323ad3} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d9fffb27-d62a-4d64-8cec-1ff006528805} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{0d26bc71-a633-4e71-ad31-eadc3a1b6a3a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{d518921a-4a03-425e-9873-b9a71756821e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{f42228fb-e84e-479e-b922-fbbd096e792c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{59c7fc09-1c83-4648-b3e6-003d2bbc7481} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68af847f-6e91-45dd-9b68-d6a12c30e5d7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9170b96c-28d4-4626-8358-27e6caeef907} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{d1a71fa0-ff48-48dd-9b6d-7a13a3e42127} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{ddb1968e-ead6-40fd-8dae-ff14757f60c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f138d901-86f0-4383-99b6-9cdd406036da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MyWebSearchService (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
(No malicious items detected)
Folders Infected:
C:\Program Files\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver\Images (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\1.bin (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\Avatar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\firefox (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\firefox\chrome (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare (Spyware.MarketScore) -> Delete on reboot.
C:\Program Files\OpinionSquare\components (Spyware.MarketScore) -> Delete on reboot.
C:\Users\Tri\AppData\Roaming\WeatherDPA (Adware.Hotbar) -> Quarantined and deleted successfully.
C:\Users\Tri\AppData\Roaming\WeatherDPA\Weather (Adware.Hotbar) -> Quarantined and deleted successfully.
C:\Users\Tri\AppData\Roaming\WeatherDPA\Weather\WeatherDPA (Adware.Hotbar) -> Quarantined and deleted successfully.
C:\Users\Tri\AppData\Roaming\WeatherDPA\Weather\WeatherDPA\Weather_XML (Adware.Hotbar) -> Quarantined and deleted successfully.
Files Infected:
C:\Program Files\MyWebSearch\bar\1.bin\MWSSVC.EXE (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SRCHMN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3DTACTL.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HISTSW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3POPSWT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3MSG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3HTML.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3OUTLCN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SKIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SCRCTR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSSRCAS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3CJPEG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HTTPCT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3REPROX.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOEPLG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Windows\System32\f3PSSavr.scr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Users\Tri\downloads\porn.video.5299.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3BKGERR.JPG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HKSTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3PSSAVR.SCR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3REGHK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3RESTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SCHMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SPACER.WMV (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3WALLPP.DAT (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3WPHOOK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\FWPBUDDY.PNG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3AUXSTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3DLGHK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3HIGHIN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3IDLE.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3IMPIPE.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3MEDINT.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SKPLAY.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SLSRCH.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOESTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\firefox\CHROME.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\firefox\INSTALL.RDF (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\firefox\chrome\M3FFXTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHECKERS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHESS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\REVERSI.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\CM.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\MFC.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\PSS.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\SMILEY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\WB.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\ZWINKY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\DOG.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\FISH.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\KUNGFU.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\LIFEGARD.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAID.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAILBOX.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\OPERA.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\ROBOT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SEDUCT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SURFER.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\s_pid.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\chrome.manifest (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\install.rdf (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\opls64.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\opnsqr.exe (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\opnsqr64.exe (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\opoci.bin (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\opph.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\opservice.exe (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\OpinionSquare\opxf.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Users\Tri\AppData\Roaming\WeatherDPA\Weather\WeatherStartup.xml (Adware.Hotbar) -> Quarantined and deleted successfully.
Scan saved at 6:58:15 PM, on 1/23/2010
Platform: Unknown Windows (WinNT 6.01.3504)
MSIE: Internet Explorer v8.00 (8.00.7600.16385)
Boot mode: Normal
Running processes:
C:\Windows\system32\taskhost.exe
C:\Windows\system32\taskeng.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Windows\System32\rundll32.exe
C:\Windows\vsnp2uvc.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Hp\HP Software Update\hpwuSchd2.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe
C:\Program Files\Microsoft Security Essentials\msseces.exe
C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
C:\Program Files\Windows Sidebar\sidebar.exe
C:\Program Files\Hewlett-Packard\Shared\HpqToaster.exe
C:\Windows\system32\wuauclt.exe
C:\Windows\system32\SearchFilterHost.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.ask.com?o=15367&l=dis
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://us.rd.yahoo.com/customize/ie/defaults/su/msgr8/*http://www.yahoo.com
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://us.rd.yahoo.com/customize/ie/defaults/sb/msgr8/*http://www.yahoo.com/ext/search/search.html
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://us.rd.yahoo.com/customize/ie/defaults/sp/msgr8/*http://www.yahoo.com
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://us.rd.yahoo.com/customize/ie/defaults/su/msgr8/*http://www.yahoo.com
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
R3 - URLSearchHook: UrlSearchHook Class - {00000000-6E41-4FD3-8538-502F5495E5FC} - C:\Program Files\Ask.com\GenericAskToolbar.dll
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O1 - Hosts: ::1 localhost
O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: (no name) - {1E8A6170-7264-4D0F-BEAE-D42A53123C75} - c:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.5\NppBho.dll
O2 - BHO: BitComet ClickCapture - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - C:\Program Files\BitComet\tools\BitCometBHO_1.3.3.2.dll
O2 - BHO: Yahoo! IE Suggest - {5A263CF7-56A6-4D68-A8CF-345BE45BC911} - C:\Program Files\Yahoo!\Search\YSearchSuggest.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.3.4501.1418\swg.dll
O2 - BHO: Ask Toolbar BHO - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll
O3 - Toolbar: Show Norton Toolbar - {90222687-F593-4738-B738-FBEE9C7B26DF} - c:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.5\UIBHO.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O3 - Toolbar: Ask Toolbar - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [snp2uvc] C:\Windows\vsnp2uvc.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [ccApp] "c:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [hpWirelessAssistant] %ProgramFiles%\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [Performance Center] C:\Program Files\Ascentive\Performance Center\APCMain.exe -m
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe"
O4 - HKLM\..\Run: [Symantec PIF AlertEng] "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll"
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [WAWifiMessage] %ProgramFiles%\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe
O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKLM\..\Run: [My Web Search Bar Search Scope Monitor] "C:\PROGRA~1\MYWEBS~1\bar\1.bin\m3SrchMn.exe" /m=2 /w /h
O4 - HKLM\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
O4 - HKLM\..\Run: [MSSE] "C:\Program Files\Microsoft Security Essentials\msseces.exe" -hide
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [swg] "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
O4 - HKCU\..\Run: [DW6] "C:\Program Files\The Weather Channel FW\Desktop\DesktopWeather.exe"
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O8 - Extra context menu item: &D&ownload &with BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddLink.htm
O8 - Extra context menu item: &D&ownload all video with BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddVideo.htm
O8 - Extra context menu item: &D&ownload all with BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddAllLink.htm
O8 - Extra context menu item: &Search - http://edits.mywebsearch.com/toolbaredits/menusearch.jhtml?p=ZCxdm860YYUS
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Send image to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O8 - Extra context menu item: Send page to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra button: PokerStars - {3AD14F0C-ED16-4e43-B6D8-661B03F6A1EF} - C:\Program Files\PokerStars\PokerStarsUpdate.exe
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: BitComet - {D18A0B52-D63C-4ed0-AFC6-C1E3DC1AF43A} - res://C:\Program Files\BitComet\tools\BitCometBHO_1.3.3.2.dll/206 (file missing)
O13 - Gopher Prefix:
O16 - DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} (SpinTop DRM Control) - file:///C:/Program%20Files/Monopoly/Images/stg_drm.ocx
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: CyberLink Background Capture Service (CBCS) (CLCapSvc) - Unknown owner - C:\Program Files\HP\QuickPlay\Kernel\TV\CLCapSvc.exe
O23 - Service: CyberLink Task Scheduler (CTS) (CLSched) - Unknown owner - C:\Program Files\HP\QuickPlay\Kernel\TV\CLSched.exe
O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Com4Qlb - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\Com4Qlb.exe
O23 - Service: COM Host (comHost) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: HP Health Check Service - Hewlett-Packard - c:\Program Files\Hewlett-Packard\HP Health Check\hphc_service.exe
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Roxio\Roxio MyDVD Basic v9\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Symantec IS Password Validation (ISPwdSvc) - Symantec Corporation - c:\Program Files\Norton Internet Security\isPwdSvc.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: LiveUpdate Notice Service Ex (LiveUpdate Notice Ex) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: LiveUpdate Notice Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
O23 - Service: OpinionSquare - Unknown owner - C:\Program Files\OpinionSquare\opservice.exe (file missing)
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
O23 - Service: Symantec AppCore Service (SymAppCore) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
O23 - Service: uvnc_service - UltraVNC - C:\Program Files\UltraVNC\WinVNC.exe
O23 - Service: XAudioService - Conexant Systems, Inc. - C:\Windows\system32\DRIVERS\xaudio.exe
End of file - 12987 bytes
Please rerun hijackthis and place a check next to these entries.
Then click on fix checked at the bottom.
Did Malwarebytes ask you to reboot the computer and have you done so? There are still entries that it should have deleted. PLease provide me with an uninstall list by using hijackthis.
Open hijackthis and click on open the misc tools section, click on open uninstall manager, click on save list, click on save. Copy and paste that log into a reply here.
You are running an outdated version of Java. Please go into add/remove programs and uninstall all version of java listed, can be labeled as java or j2se runtime. After uninstalling all older versions go here and download the lastest version.
http://www.java.com/en/download/index.jsp
Done.
Yes.
Norton Internet Security (Symantec Corporation)
Norton Protection Center
NVIDIA Drivers
OpenOffice.org Installer 1.0
OpinionSquare
PDF Settings
PokerStars
QuickTime
RealPlayer
Rhapsody
Rhapsody Player Engine
Roxio Activation Module
Roxio Creator Audio
Roxio Creator Basic v9
Roxio Creator Copy
Roxio Creator Data
Roxio Creator EasyArchive
Roxio Creator Tools
Roxio Express Labeler 3
SCRABBLE
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for 2007 Microsoft Office System (KB973704)
Security Update for CAPICOM (KB931906)
Security Update for Microsoft Office Excel 2007 (KB973593)
Security Update for Microsoft Office PowerPoint 2007 (KB957789)
Security Update for Microsoft Office system 2007 (972581)
Security Update for Microsoft Office system 2007 (KB969613)
Security Update for Microsoft Office system 2007 (KB974234)
Security Update for Microsoft Office Visio Viewer 2007 (KB973709)
Soft Data Fax Modem with SmartCP
SPBBC 32bit
Sportsbook.com
Symantec Real Time Storage Protection Component
SymNet
Synaptics Pointing Device Driver
UltraVNC 1.0.4 RC8
Unity Web Player
Update for 2007 Microsoft Office System (KB967642)
Update for Microsoft Office 2007 Help for Common Features (KB963673)
Update for Microsoft Office Excel 2007 Help (KB963678)
Update for Microsoft Office InfoPath 2007 (KB976416)
Update for Microsoft Office OneNote 2007 Help (KB963670)
Update for Microsoft Office Powerpoint 2007 Help (KB963669)
Update for Microsoft Office Script Editor Help (KB963671)
Update for Microsoft Office Word 2007 (KB974561)
Update for Microsoft Office Word 2007 Help (KB963665)
VobSub v2.23 (Remove Only)
WD Diagnostics
WD Firewire HID Driver
Windows Live Sign-in Assistant
Windows Media Player Firefox Plugin
Xvid 1.1.3 final uninstall
XviD MPEG4 Video Codec (remove only)
Yahoo! Browser Services
Yahoo! IE Search Suggest
Yahoo! Install Manager
Yahoo! Internet Mail
Yahoo! Messenger
Yahoo! Search Protection
Yahoo! Toolbar
ACE Mega CoDecS Pack
Acrobat.com
Acrobat.com
Activation Assistant for the 2007 Microsoft Office suites
Adobe AIR
Adobe AIR
Adobe Anchor Service CS3
Adobe Asset Services CS3
Adobe Bridge CS3
Adobe Bridge Start Meeting
Adobe Camera Raw 4.0
Adobe CMaps
Adobe Color - Photoshop Specific
Adobe Color Common Settings
Adobe Color EU Extra Settings
Adobe Color JA Extra Settings
Adobe Color NA Recommended Settings
Adobe Default Language CS3
Adobe Device Central CS3
Adobe ExtendScript Toolkit 2
Adobe Flash Player 10 Plugin
Adobe Flash Player ActiveX
Adobe Fonts All
Adobe Help Viewer CS3
Adobe Linguistics CS3
Adobe Media Player
Adobe PDF Library Files
Adobe Photoshop CS3
Adobe Photoshop CS3
Adobe Reader 9
Adobe Setup
Adobe Stock Photos CS3
Adobe Type Support
Adobe Update Manager CS3
Adobe Version Cue CS3 Client
Adobe WinSoft Linguistics Plugin
Adobe XMP Panels CS3
Apple Mobile Device Support
Apple Software Update
Ask Toolbar
Audacity 1.2.6
Auto Gordian Knot 2.40
AviSynth 2.5
Bejeweled 2 Deluxe
BitComet 1.10
Bonjour
Color Efex Pro 3.0 Complete
CometBird (3.0.9)
Conexant HD Audio
Coupon Printer for Windows
CPUID CPU-Z 1.52.2
Creative MediaSource
Creative Removable Disk Manager
Creative System Information
DVD Shrink 3.2
ESU for Microsoft Vista
Garmin Communicator Plugin
Google Updater
Hewlett-Packard Active Check
Hewlett-Packard Asset Agent for Health Check
HijackThis 2.0.2
HP Active Support Library
HP Active Support Library 32 bit components
HP Customer Experience Enhancements
HP Easy Setup - Frontend
HP Help and Support
HP Integrated Module with Bluetooth wireless technology
HP Pavilion Webcam Driver for Vista v061.001.00005
HP Photosmart Essential 2.0
HP Quick Launch Buttons 6.20 B1
HP QuickPlay 3.2
HP Total Care Advisor
HP Update
HP User Guide 0042
HPNetworkAssistant
IrfanView (remove only)
iTunes
Java(TM) 6 Update 5
Java(TM) SE Runtime Environment 6
Lexmark 510 Series
LimeWire 4.12.15
LiveUpdate Notice (Symantec Corporation)
Microsoft Antimalware
Microsoft GIF Animator
Microsoft Office 2007 Service Pack 2 (SP2)
Microsoft Office Excel MUI (English) 2007
Microsoft Office Home and Student 2007
Microsoft Office OneNote MUI (English) 2007
Microsoft Office PowerPoint MUI (English) 2007
Microsoft Office Proof (English) 2007
Microsoft Office Proof (French) 2007
Microsoft Office Proof (Spanish) 2007
Microsoft Office Proofing (English) 2007
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
Microsoft Office Shared MUI (English) 2007
Microsoft Office Shared Setup Metadata MUI (English) 2007
Microsoft Office Word MUI (English) 2007
Microsoft Silverlight
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
Microsoft Visual C++ 2005 Redistributable
Microsoft Works
Monopoly
Mozilla Firefox (3.5.7)
MP3Grabber
MSCU for Microsoft Vista
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB941833)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
Musicnotes Player V1.23.1
My Web Search (Cursor Mania)
NVIDIA Drivers
OpinionSquare
PDF Settings
PokerStars
QuickTime
RealPlayer
Rhapsody
Roxio Creator Audio
Roxio Creator Copy
Roxio Creator Data
Roxio Creator Tools
SCRABBLE
Sportsbook.com
UltraVNC 1.0.4 RC8
Unity Web Player
WD Diagnostics
Yahoo! Messenger
Yahoo! Toolbar
Make sure these get uninstalled.
Ask Toolbar
Java(TM) 6 Update 5
There was a problem starting
C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsbar.dll
The specified module could not be found.
Goto C:\program files\my websearch and delete the folder. Then go back into the uninstall manager in hijackthis and then highlight it and then click on "delete this entry" for that item.
